timing cover gasket
Started by turbo boy, June 30, 2008, 06:47:21 PM
turbo boy
hello everyone. Im nearly finished rebuilding the fd block, only problem is the timing cover gasket doesn`t line up properly missing the top right bolt hole completly. When i ordered the rebuild kit i was assured it was for an fd. Can this be bodged or is it normal for it to miss the top right bolt hole.
davehg
its normal to miss the hole on the oil pump cover
turbo boy
turbo boy
Does this look right? Is it normal to miss the right bolt hole complety?
davehg
thats the correct gasket and completely normal.
turbo boy
Nice one mate, i`ve been stressing the last few days. Had visions of me bodging it up! Thanks again.
