Idling problem when cold engine
Started by AndersE, June 09, 2008, 10:54:56 PM
AndersE
When the engine is cold and gear in neutral the idle is ok. But as soon i put in a gear OR put on AC the idle goes up and down around 300-1000rpm and almost stall the engine.
The hotter the engine gets, the less problem with idle i have.. When really hot the problem is gone.
Is this the TPS playing tricks on me?
AndersE
*bump*
I have adjusted the tps, it was little off. But the problem still exists.
As soon i put in gear and/or turn on a/c the rpm goes up/down almost stalling engine. If i just press down the clutch i don\'t notice anything.
Some people told me to check the clutch switch, but i don\'t understand how that can change the idlespeed. Anyway the idle does not change when engaging the clutch.. only when i put it in gear.
AndersE
No one??
I checked the ISC solenoid valve and it is within specs, but the engine stalls everytime i turn on headlights AND have it in gear. I tried disconnecting the ICS soleniod but there were no change..
Normal idling without lights/ac or gear is ok and around 850rpm..
SmbFD3S
Do you have an Apexi PFC? or a multimeter?
See what the voltage at the battery is doing in each of the instances, it should be a pretty constant 14v ish with no lights or a/c or about 13.5v with lights and/or a/c...
Worth a go, does sound like an electrical problem tbh
\'92 UK RX7 FD
\'86 Honda CRM250R stroker
\'11 BMW 320d ED
AndersE
Disregard above that it works when hot engine. It does not idle correct at any temp with ac on/ lights on/ in gear. In neutral with all electrical off it idles ok around 750rpm.
I measured voltage when turning on ac / lights and it fluctuates a little (13.5-13.9v). I have checked grounding at the battery and the groundingwire on top of the engine.
There is no difference when i disconnect the ISC valve. What i understand ISC valve should compensate the idle when Lights / AC etc  is engaged.
It measures within tolerances or just (it\'s 12.3ohms), but i do not know if it gets any power.
Can i remove it and apply some voltage to ckeck that it moves?
PS: i have original ecu, and everything in the engine is original.
