Who Supplies your Methanol?
Started by Fendamonky, June 19, 2008, 11:30:01 AM
Fendamonky
This is a question for all the guys who are running Water/Meth injection systems. I\'ll be getting mine installed here shortly and have begun looking around for a good, consistent, source of Methanol to do my mix with.
I checked Halford\'s, they don\'t have straight meth and are clueless on the % of their windscreen fluid, not wanting to use that if it could be dodgy. I\'m thinking I may end up using windscreen washer fluid of some sorts, just not sure which (British) one is tried and true...
So I\'m curious where everybody else finds their meth.
Cheers,
Levi
davehg
i use a mix of screen wash(contains methanol) and distilled water
Lum
I use B&Q concentrated screen wash mate!
davehg
AtomicRex
We can supply methanol
The stuff we supply is 99.8% pure, and comes with the additives needed to slow down the onset of premature corrosion.
This will work a lot better than screen wash!  Happy to deliver a big job load to Bristol
£1.20 per litre + VAT
Fendamonky
Hmm... how much to post it to PE19 2AG? Say 15 liters at a time..
AtomicRex
Posting is an issue as for some strange reason DHL and the likes wont post it saying it can set on fire!!
I can get a drum sent to you, the cost for a 25L drum is £26.50 + VAT
Fendamonky
Awesome! I\'m skint atm (spelling?) but you\'ve got yourself one customer =)
\'course, I\'ll do a little comparative pricing first to be sure. However, unless otherwise states count me in =)
