power fc
Started by yonner, March 29, 2004, 08:03:16 PM
yonner
is tha apexi power fc just plug and play
can i jsut fire it in the harnes chose rx7 fd blah blah and it worx and then is it simple to ajus ththe fule ratio??? + if i ahev alot of mods sould i keep the air fuel ration the same as stock
when your life is a mess light one more ciggaret its so logical!
Steve Burnett
As far as I know you can just plug it in a run with it, but......
That is the stock setting, if you are going to add mods to your car you would have to get the ECU mapped. The problem with being a Scottish FD owner is that the nearest place to get it mapped is Manchester (Pip @ WGT).
yonner
mmmmmm so whats the point in geting it then and ahts the point in the comander can i not remap it with that or my laptop?
J4P RX
Yes you can, but are you good enough to do it is the issue really.
Lee
GaryS
The problem is the rotary engine needs \'tighter\' tuning than a boinger.  I\'m sure if you knew what you were doing you could tune it on suitable roads, but in the log run you\'d need a dyno session with some one who knew what they were doing.
People do run the stock map, but personally I would not risk it.
Project Zero
If you know someone with an Apexi PFC and the same mods as you have, you could ask for a copy of their settings and just punch them in with your commander or laptop.
 Ask them very nicely ;)
This still wouldn\'t be perfect but better than the base map.
PZ
