new ecu!
Started by johnnycrx7, June 23, 2008, 08:52:34 PM
johnnycrx7
[FONT=\'Arial Unicode MS\']guys bought this ecu and was wondering dose anyone have one in theres and what is it like. do i have to get anything done to it before i can plug it in. [/FONT]
[FONT=\'Arial Unicode MS\'][/FONT]
[FONT=\'Arial Unicode MS\']JDM Knight Sport 4Beat set [/FONT][FONT=\'Arial Unicode MS\'][FONT=\'Arial Unicode MS\']Knight Sports EBS IV Boost Controller Knight Sports SCA Plug and Play Ecu Harness
Tuned:
Aftermarket Air Filter
[FONT=\'Arial Unicode MS\'][FONT=\'Arial Unicode MS\']Aftermarket Exhaust
Boost Up
Fuel levels & ignition etc remapped
Fuel cut removed
Rev limiter higher
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
BlitzBoy
show us some pics, did you get the ecu and the boost controller?
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
Johnerz
i have an ebs iv mate.  just took it out recently when i got my apexi
handy enough, got hi/low boost settings.  the harness plugs in between the ecu and the loom then hose goes thru and connects to the uim to get the boost pressure.  the ecu itself is the stock one (i believe) that knightsports modified.
there was some links i found with help on fitting it and a thread on setting it up. cuz i doubt u got destructions for it.  if you want i can have a look and see if i can find it to help you?  n yup its plug n play
1997 FD3S Type RS
BlitzBoy
ahh so it comes with the ECU with the knighsports chip, cool, if you fit it to your car make sure you put it on the dyno so they can check the AFR (air fuel ratio) is safe, as it might have been mapped to 100 Octane jap fuel
New Project
Jimjitsu
I think most of these are mapped to jap fuel so deffo will need checking
Johnerz
boost controller was available seperate to the ecu too.  i dont know if they still make em cuz they are not on the site.
my car had the stock ecu, but the EBS boost controller fitted.  the controller also has a fuel cut defender and sequential control adapter.
1997 FD3S Type RS
Timmy
I\'ve heard that jap fuel in the 90\'s was 97ron and not 100ron like it is now, so it may well be safe need checking tho. I will say i have maxed out stock injectors on the same mods.
Jin Kazama
Quote from: johnnycrx7;511349[FONT=\'Arial Unicode MS\']guys bought this ecu and was wondering dose anyone have one in theres and what is it like. do i have to get anything done to it before i can plug it in. [/FONT]
Tuned:
Boost Up
Fuel cut removed
Rev limiter higher
[/FONT]
[/FONT]
[/FONT]
[/FONT]
I have a 4beat ECU you could have had for free if I knew you wanted one! There isn\'t alot that can be done with these (well, outside of Knightsports HQ anyway) as nobody can interface with them in the UK. A bit risky plugging this into your car imo, but if you must then make sure your ECU has the correct loom for your car ie.8 bit loom will not fit a 16 bit car.
johnnycrx7
yeh john that would be great cause i have a long blue wire on the harnes and sont know what its for. if you could get the picks for me. sound
johnnycrx7
#9
www.bebo.com/PhotoAlbum.jsp?PhotoNbr=1&MemberId=391770154&PhotoAlbumId=8110699230
here is the picks of the ecu lads will ya have a look and let me hnow t
what ya think i shoud do with it. and that blue wire off it as well. sound.
johnnycrx7
yeh guys mines the same has the ebs with the fuel cut defender and sequential control adapter and the gauge for the dash. do i just y the boost pipe from my apexi gauge to the back of the ebs. and what do i have to set it to on the gauge.
Johnerz
Quote from: johnnycrx7;511486yeh john that would be great cause i have a long blue wire on the harnes and sont know what its for. if you could get the picks for me. sound
mate the site is down that had the how-to for fitting it. its was clubrx.org, some of the ones on rx7club said his site got hacked im afraid. ill look at mine when i get home as i had a loose wire which came out of one of the plugs and was outside the black cable tidy that all the other wires run thru. post a few pics up if you can.  the government blocks bebo at work lol
1997 FD3S Type RS
