Apexi Readout
Started by SmbFD3S, May 21, 2008, 12:01:56 AM
SmbFD3S
Ok, so i\'ve just been out and had a bit of a drive in the rex, well actually for about the last 2 and half hours :)
Thought i\'d drive around a bit and watch the Apexi Commander readout was.  On the way back home (down a dual carriage) i put on the apexi on 8 line readout and locked it so it read highest values and gave it some from standing til i reached the end of the dual carriageway, approx 2 miles and this was the result:-
Oh and bearing in mind the engine is stock apart from HKS pipes, custom 3" exhaust and on 59017 miles on original engine so didn;t push it that hard on revs:-
So this was foot planted to the floor throughout the gears.  It always has boosted fine to be honest, however i thought standard boost was 10 psi?  and if you convert kg/cm2 into psi, this gives 12?
Do them figures look ok? i assume i can get more out of it due to being on 85% injector duty ?
\'92 UK RX7 FD
\'86 Honda CRM250R stroker
\'11 BMW 320d ED
Fats
Looks bang on for what you\'ve got fitted, you\'ll find if you took the rev\'s to 8k the injector duty would be in the 90\'s.
The boost is slightly higher with a pfc fitted, I found that before I had my pfc fitted I was only hitting .8 max but it would hit .9 after it was fitted and mapped.
SmbFD3S
Oh and it\'s still running on base map (for nearly a year now) and seems happy with it to be honest....
\'92 UK RX7 FD
\'11 BMW 320d ED
