boost pills
Started by danny_m94, May 09, 2008, 09:44:31 AM
danny_m94
last night i found a leak in one of the boost pill lines so i cut it out and pushed it into a piece of silicone hose
is this likely to be ok
also i have a kinghtsports boost controller do i need these pills
leon
Yes you do. the Knightsports EBC3 is a good peice of kit too :mmmm
I woof in your general direction.
danny_m94
yeh i heard that but im strugling with mine to get it rite somtimes it overboosts n a couple of times its been underboosting and now ive just done the non sequrntial setup i have massive boost spikes
leon
You got the boost controller setup right?
On the main box there is a blue knob turn that to the Left (7 oclock position) this dial controlls how quick the boost is to build.
The other two switch\'s are W / N (wide / Narrow) set this to W i think is best (should give you best controll)
The last one S / P - Swing or Poppet valve type.. we are using swing i do belive.
On the handheld make sure you set the boost level you want in the 2nd mode function - this is in KGCM2 (similar to bar)
phew all that off the top of my head :Giggle
but yes the pills are used to controll the actuators that controll the wastegate so if they are not right it could over boost.
