Whats the first thing to go?
Started by ScuttleRX, March 09, 2004, 07:15:06 PM
ScuttleRX
When up-ing the boost on a standard car whats the first components that will fail?
Ive heard that the stock cooler is good for about 0.9 bar, how much can stock twins handle if the cooler is uprated. And if twins are uprated what would be the next thing to do?
ever-curious andy
Depends whats already been done. Here\'s a list of things to be done, sort of in order.
1, ECU
2, Fuel System (uprated pump/fuel pressure reg.)
3, Exhaust System (remove cats)
4, Front Mount Intercooler
5, Better Brakes
6, Single Turbo
7, Bucket Under Seat, wet wipes in glove box. ;)
ScuttleRX
lol@ no 7 :rollin
Just sort of curious as to what the weakest link would be if the boost was wound up, I know the general concensus is not to go more than 0.9 on a standard set up (except ecu and exhaust/dowpipe), wondered whether that was just because the turbos couldnt handle it or whether there were other things like the cooler which would also be at risk
Glenn Butcher
And after each of the stages a DYNO tune should be done - well maybe not after 5. and 7  :)
Thanks,
Glenn Butcher
QuoteOriginally posted by ScuttleRX
lol@ no 7 :rollin
Apex Seals - lean/detonation etc.
But good tuning can help prevent this.
Thanks,
20B_boy
The twins are out of their efficiency range much over 15psi. 16-18psi should see them dead pretty quick. They generate a lot of heat when making more than stock boost. The next thing to go I would guess will be your motor if its not pinned. Much more than a bar and flex/twisting under high boost will do lots of damage...
R.
ScuttleRX
QuoteThe next thing to go I would guess will be your motor if its not pinned. Much more than a bar and flex/twisting under high boost will do lots of damage...
Haven\'t seen much about this, whats normally done to prevent it. Is it stronger engine mounts, or chassis strengthing something along these lines..?
Carl
QuoteOriginally posted by gbutcher
Maybe No7 would still be needed cos you  might lead to number 2\'s when you get the dyno bill?
Carl
Glenn Butcher
QuoteOriginally posted by Carl
Carl
:D
Thanks,
Shaq
ScuttleRX
i would say stock twins are good for 15 psi
but i dont know if the stock cooler would be able to cope with this maybe a SMIC ?
shaQ
