porting
Started by turbo boy, May 01, 2008, 08:06:43 PM
turbo boy
Hello everyone. Im currently rebuilding my fd and yesterday received my mild streetport template from pineapple racing. Today my dad took the plates to work to get em ported. There about 90% complete at the moment, just abit more smoothing out to do which we will do at home. What i want to know is, can you port the housings? The open sleave located at the bottom of each housing is quite rough and has a jagged edge lip inside. Can this sleave be taken out and then ported like the plates? If i knew how to post pics you`re know what im talkin about.  cheers
Fendamonky
Do you have the pictures hosted on a website (Photobucket, Flikr, etc)? If so just copy and paste the link to the right of the picture (or directly below, based off the setup) that has around it. The description for the link should specify it\'s for forum use.
BlitzBoy
you are talking about the exhaust ports on the Rotor housings, leave the sleaves in and just smooth out , there is pics on the net to make the exhaust ports bigger, but I would not bother on the Pineapple templates as they are quite mild, what turbo you going to run
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
Ricco_04
Hopefully this doesnt sound too silly, but is there any benefit to porting out the exhaust ports but leaving the standard size intake ports? (fc)
BlitzBoy
it will effect your torque numbers by doing that from what I read, so keeping intake the same but increasing the exhaust port size torque will go down as there is less back pressure, hp may rise slightly, but I think an expert on porting will need to confirm what I think.
New Project
BlitzBoy
here is a link on exhaust porting seems you can get templates for this as well
http://www.mazdatrix.com/faq/portexh.htm
New Project
BlitzBoy
New Project
Brett
I ran my old EGi with no sleeves and mild ports on the inlet - never had it dyno\'d, but it pulled quite well :)
Brap Brap Brap Brap
turbo boy
Cheers for the info lads, much appreciated. I think i`ll just smooth the exhaust ports seeing that im running stock twins, nothing hardcore.
BlitzBoy
Quote from: Brett;495991I ran my old EGi with no sleeves and mild ports on the inlet - never had it dyno\'d, but it pulled quite well :)
Not recommended on a street driven Turbo rotary as it disapates the exhaust heat
New Project
turbo boy
Fduk it i might bridgeport the rotor housings (gotta be a first!), bridgeport the plates, strap two garrett gt6041 turbos, wire eight 1680cc injectors, remap it to 3bar of boost @1000hp whilst despatching 7sec 1/4miles! never mind my apex seals, i might fduk my intake welds!:rollin:rollin
Brett
Quote from: BlitzBoy;496006Not recommended on a street driven Turbo rotary as it disapates the exhaust heat
Quite good at knackering cheaply made hurley headers too :Giggle
Brap Brap Brap Brap
Ricco_04
Thanks for the info guys - Sounds like it would be better for me to leave the ports alone :Thumbs-up
