Will I be Lean?
Started by michal marzec, March 09, 2004, 06:18:02 PM
michal marzec
Hiya all,
Just wanted to double check:
Can I get away with Full De-Cat system on standard ECU IF I left the original back box on?
Car is 100% standard apart from that.
                          Thanx Michal
Robertio
Odds are you would be lean, as always the only sure way to find out is to get it checked.  Personally I wouldn\'t take out a cat without an appropriate ECU in place.
When I did this I was ok, but thats not to say that yours will be ok, best to get it checked at a rolling road station.
michal marzec
cool thnx,
Ive got a techedge w/b sensor but need laptop for display. what kind of runs do i need to do in the car to make sure its ok?
when would it most likely be lean RPM/Gear/Speed?
                                    michal
