a little help please guys
Started by the hat, May 24, 2009, 02:02:22 AM
Quote from: the hat;610507yes i understand the no need to rev the car that high but when your sideways your not really paying that much attention to how high the revs go
Just make sure you have uprated the rad for the extra heat that the engine would produce at high revs, also install an underdrive pully if you are constantly at high revs, on the plus side, the more you rev it, the more oil gets injected :)
the hat
ok where can i get an underdrive pulley from and the rad isn the list of items soon to be installed
mukumu kurubushi
Quote from: the hat;610545ok where can i get an underdrive pulley from
racing beat do one
http://www.racingbeat.com/resultset.asp?PartNumber=11479
the hat
ahh i already have one of these fitted i thought it was actually the water pumppulley itself you were speaking of
Louis Pulles
Hi,
I´m a member of the dutch Rx-7 club and I had the same problem with my wiperunit from our FC convertible. After several months of seeking for the replacements, I found the right relays. So I replaced the relays and now it works again. In the last months I have already replaced several relays here in the Netherlands and even from Germany. I also check the unit if the dashboardlight is working. It doesn´t matter if the unit is from a coupe or convertible.
flatout
if you find out what relay it is i should have a spare, i have loads a parts
colin5524
The popup light thing seems common as well, my passenger side stopped working and i put it up and down once , was in the garage for a few weeks came out nd its working now, might be some water trapped in about the wiring?
Louis Pulles
The relay is difficult to remove. The first 3 units went wrong (broken down). But now I have the technique to remove them. Because the print is old (almost 20 years) and it is dubble sided. I solder new sealed relays in it, so the water can not come into the relay. (which is the most commen reason)
