will hks skyline pump fit?
Started by m4drx, April 17, 2008, 09:51:47 PM
BlitzBoy
You will be fine on that pump
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
BlitzBoy
Quote from: nikpSo with the standard wiring, what sort of voltage does the fuel pump usually get?
who knows as most peoples wiring is 15 years old on a FD, some have seen as little as 8 volts (which will give very poor flow) some see the normal 12. with rewire mod you guaranteed almost 13 volts and hence more flow
New Project
jammy_uv
for better voltage get a sard Fuel pump relay kit - or i think the MSD voltage booster might do - never used the msd myself but i am using the sard voltage booster and pip has said its worth it.
secondly get good grounding kit - always helps in general and its cheap.
reliability mods are vital.
