Windscreen wipers - How to improve??
Started by noyzboy, April 24, 2008, 07:58:36 PM
I use that Mer Windscreen cleaner, which certainly helps.  It\'s also worth removing the film that build up on the wipers with a bit of vinegar (or glass cleaner if you don\'t like the smell) from time to time.
Rainex is also good, but can react with some polishes if you get spillages
probedb
Quote from: Andy_k;493744I have a pair of the Piaa wipers and they are alot better than stock. After a few wipes i don\'t use them unless im stationary.
Me too, once you get to 70 you can put them on intermittent :)
