Back Knocking Noise
Started by fraser87uk, March 21, 2008, 10:37:57 AM
fraser87uk
Hi there. A some of you know i went to see my first rex last night and i bought it!
It has problems hence the price i got it for. One of the problems is thback suspension knocks like a bitch. Very noisy over bumps etc. When you stop the car and get out and push the back down you can here it knocking. Any ideas guys?
Fraser
rico2k_uk
spherical bearing probably shot to ****. bit of a pain to change (cheap part tho) as you need a pneumatic press imo. check all the other bushes as well.
memski
Yup, bound to be rear pillowballs, mine used to creak as well when you push the rear down or let it off the jack to weight bear. 3 each side, not too bad to do, car will feel like new afterwards :D
fraser87uk
Quote from: memskiYup, bound to be rear pillowballs, mine used to creak as well when you push the rear down or let it off the jack to weight bear. 3 each side, not too bad to do, car will feel like new afterwards :D
Yeah after that and an engne rebuild. Think an Apex seal is gone. But it drives a bit well for that. Might be a hose of sorts but im not holding my hopes out.
