Got the FD home from the seller
Started by BioMech, March 12, 2008, 10:13:50 PM
BioMech
So wonderfulöl day people! finally got the lady maztilda fd home from the seller.
There was few things that got my attenttion.
first of all. when i started her cold, there was NO 3000rpm idle, it went to around 800 rpm almost right away. I suppose this means that the idle thingy is modded/disabled?
I also noticed that the adle was a bit rough, not jumping around or so, but i would say that it was like.....hmmm sounded like a piston engine with a little bit too low idle..a bit rough, maybe like between 800 and 900 rpm small hunting. i drove her home (15km\'s) and the idle was fine. suggestions?
The seller (one person company/impoprter) said also that he thinks that there is the non sequential mod done as he felt that the boost curve is stable. i havr to hook up a gauge and see what it says.
everything else was fine. i hate the oem radio as it finds one swedish language station and i hate those guys as much as Indiana Jones hate Nazi\'s :D
wheel alligment has to be done as it pulls a bit to the right.
Now going to buy some dexelia 10W-30, oil filter that seems to be same as rx-8 one, change the coolant and drivetrain oils.
have you people used the Red Line water wetter? should i add the whole bottle (1 liter i think) to the system and then add 30% glykol/water mix? Oh and does distilled water mean the same water you use in the battery? sorry my language barrier
Jit
have you got a link to the advert from which you bought it?
John_Hudson
if non seq the 3k warmup should be disabled, mine sure was if you look at the back of the plenum there should be a metal pipe with nothing attached?  thats if left on o/c  just let her warm up before you drive and should be fine bud : )
BioMech
Quote from: Jithave you got a link to the advert from which you bought it?
no sorry. the car was on it\'s way to Finland allready when i reserved it
