sunroof not moving
Started by HOSS, January 08, 2009, 03:40:31 PM
HOSS
my sunroof doesnt open,not that i need it right now lol
but would like it to, come the summer (should we get one)
i can hear the motor working,but it does nothing ?
is this common?
any ideas on how to fix this ?
an how the chuff do i get to it to remove it :rollin
:cheers
cheers
dthebuk
well for now, you can push the back upwards to get it started.
Usually it just needs some cleaning and lubing up.
You should look at getting a workshop manual, i cant remeber the link or where it is, but they are about :D
:burnout
Brett
The sunroof mechanism on the FC has a very steep cam action - as they wear it can become a real PITA.  You may find if you drive along at 50+ the suction of the air passing over the car will open it without the assistance of a well aimed thump ;)
Brap Brap Brap Brap
HOSS
now that would certainly help
i will have a look out for one
an i may give the thump a go brett cheers
Jimi_Hendrix
My turbo II sunroof just needs me to push the button a little bit, then push the back of the sunroof up and then all i have to do is push the button again and it opens no bother.
Closes no prob too. Just give it a hand! Lol!:Giggle
TiddlesRX7
QuoteMy turbo II sunroof just needs me to push the button a little bit, then push the back of the sunroof up and then all i have to do is push the button again and it opens no bother.
Sounds like mine!
You need some lithium grease, is what prof put on mine, just push the back of the sunroof to start it moving, then grease it up :) get it done as soon as you can, else you might burn out the motors
HOSS
thanks guys
i tried the \'thump\' test :Giggle
an it worked:wiggle:wiggle:Thumbsup!
thanks gents :god
 :cheers:cheers
an cheers mitch i will get some grease onto it asap:Thumbs-up:Thumbs-up
Woo :) another happy customer lol your sunroof will soon be as smooth as your engine :D
