\'Setting up\' Coilovers
Started by shogun no 1, February 26, 2008, 04:51:58 PM
shogun no 1
I\'ve just bought a set of replacement second hand HKS Hyper D\'s but every local garage i ring up say they won\'t touch em because they need to properly set up.
Does anyone know somewhere fairly near Kingston/Croydon that can set them up??
FD3SNuttah
you bought these off ebay??
if so i think they are already assembled? it should be a matter of just fitting them.
When you set the up you have to simply adjust the damping level and the ride height. id take it to your nearest jap car tuning shop. as your in london im very sure your near a rotor specialist?
clive maybe able to point you towards someone.
rx7veilside
simple really set ride height to desired level..dont have front higher than back or instability will be a problem..then put on softest setting and gradually increase until u are happy with ride
Red and Single
Quote from: rx7veilsidesimple really set ride height to desired level..dont have front higher than back or instability will be a problem..then put on softest setting and gradually increase until u are happy with ride
You missed the bit about the 4 wheel alignment :D
Dave Hughes
matto
shogun no 1
Thanx peeps
I think i\'ve found someone
