Whats the S5 n/a got the s4 hasnt?
Started by dthebuk, February 08, 2008, 02:47:22 PM
dthebuk
just reading over the specs and the s5 apparently has a few bhp more, i read somewhere that it was down to engine managment.
So what do they do differently?
cheers
:burnout
Brett
If it\'s a UK car then there is no difference other than some new trim and power steering as standard.  The overseas models went up to 160bhp in late 89, this was due to a different port setup iirc :wave
Brap Brap Brap Brap
dthebuk
so can you change the port set up on the uk 88\'s?
:burnout
Kron
We didn\'t get the S5 NA over here though, Everything 89+ was a TII.
dthebuk
:burnout
antnicuk
looks like a very clean UK Spec Egi series 4.
There were more differences with the turbos but UK didnt get Series 4 Turbo.
dthebuk
:burnout
dthebuk
ah one other thing, can the port set up on an s4 easily be changed to the same as an s5?
:burnout
Brett
No, for the work involved u may as well give it a decent bridge :yes
Brap Brap Brap Brap
