Changing Front light bulbs!
Started by gibby250983, January 28, 2008, 03:03:40 PM
gibby250983
This will sound Soooooo stupid! But better to make sure how to do it first!
Before i go and rip the things to part how do i change the front light bulbs in my car!? i have flip up lights!
FD3SNuttah
ok, wa you do is flip the lights up - then
take off the front black panel (two screws either side)
then loosen the cover screws from the front
then flip the lights down and loosen the screws holding the cover on the back
this gives you access to the light bulb socket
take the rubber thing off
and then its just like another light really take the metal clip holding the bulb replace and fitting is the reverse of removal lol.
you may have to fiddle the cover tho so it sits flush my advice is to place it on and give the screws a slight tighten before replacing the front plastic bit incase any adjustment is necessary.
job should be a good un,
