fuel injection
Started by hondakiller87, February 27, 2004, 07:24:11 PM
hondakiller87
i have found that i have spouted a huge fuel leak and i was wondering if anyone else has had the same problem it is on the lower fuel rail ?? and i was also wondering if the injectors out of a turbo would work in a na car thnaks
Iwan
Hi,
the connector of turbo is different as of N/A. You will need to cut the connector- nose of the injector  to get the connector on it. Works fine, I have experienced no problems running turbo injectors in N/A.  (180HP injector on N/A car, duno about 200hp injectors)
REgards
Iwan
still remember,
NO ROTOR, NO MOTOR !
