couple of queries... (plz look!)
Started by <Daneh>, February 25, 2004, 08:04:26 PM
<Daneh>
ok i have some questions...
first off, is this a standard ECU?
http://homepage.ntlworld.com/daniel.keefe.106/car/rx7/umm/ecu1.jpg
http://homepage.ntlworld.com/daniel.keefe.106/car/rx7/umm/ecu2.jpg
second, can anyone tell me where the hell this cable is suppose to go... everything works and i cant figure out or find anywhere for it to go..
http://homepage.ntlworld.com/daniel.keefe.106/car/rx7/umm/cable1.jpg
i was wondering if it\'s for the center speaker now that i\'ve discovered i have one.....that doesnt work, but then that a lot of cables for 1 tiny crappy speaker...as seen here..
http://homepage.ntlworld.com/daniel.keefe.106/car/rx7/umm/centerspeaker.jpg
Third, heres a second cable i have discovered behind my stereo...which i still need someone to fill the gaping whole where the double din used to be.. :(
http://homepage.ntlworld.com/daniel.keefe.106/car/rx7/umm/cable2.jpg
it also apears i have 2 atenna cables. i asume someone must have put a new one in at some point.
thanks for any help.
Daneh
OK, the ECU is not standard, it\'s the knightsports ECU.
Cable 1 I think connects to the dash. You need to just undo the dash and feel around for sockets without plugs in. It is not for the dash speaker.
Cable 2 is an earthing strap for the stereo.
My UK car also has two atenna cables. Think it\'s just a Mazda thing.
<Daneh>
#2
ta for that, but that big cable defo aint for dash as there all filled, and everything works exept for my petrol gauge! which stoped working shortly after me removing the dash last time.
i pulled it all back out this morning and theres deffinatly no empty spaces on the back of the dash.
..anyone know how to remove the gear knob?
so casn anyone tell me what the markings on the ecu mean?
richrx
The cable looks just like one from behid the dash. Have you pulled the centre console out and looked behind there?
To remove the gear knob twist it anti-clockwise.
As for the ECU, it might be worth sending the picture of Knightsports themselves and see what they say about it.
<Daneh>
QuoteOriginally posted by richrx
So how do you connect the antenna?
i just used the one the old jap double din was plugged into and it works fine.
ta, have mailed Knightsports, located in japan! hope they can read english =/ .
any more suggestions more than welcome, i\'ve had someone suggest that the large cable is for Cruise control but i dont have it... that i know of.
mraraju
I believe that white connecter behind the cluster fits into the swith whitch may be a blank.
If you look at ur cluster there is a blank switch top left, it fits behind there.
Thx
Raju
Let me know if it is from there
<Daneh>
well it could yes but what would the point be, the switch it just a blanking plate, it must do something! :confused:
jonrx7uk
IIRC the large aerial goes to the electric aerial mast, the smaller one goes to the aerial built into the rear window de-mister...(which isn\'t really required).
mraraju
it doesnt do anythin unfortunately. Its prolly an extra switch fitted to some cars, could be cruise or for the sunroof or something. But not sure.
Sorry cannot be of more help.
Raju
