Cruise control
Started by banana-man666, November 21, 2007, 08:35:05 PM
banana-man666
Right just a quick question.
How do you use the cruise control?
Its the first car I have had with it fitted and there is no owners manual with the thing. So I have no idea how it works.
Any help greatly appreciated.
Dave
gergriffinrx7
There\'s a button on the dash to turn it on.  then drive to the required speed and press the \'set coast\' button on the steering wheel.  Use the brake or the cancel button to stop cruisin and the resume button to resume the cruise speed.  the resume button doesn\'t work if you drop below third gear.  you have to set the speed again.  the resume button also lets you increase your speed if you keep it pressed.
banana-man666
Ok thanks for the quick response but do you know which switch turns it on?
gergriffinrx7
yep
there\'s a button on the instrumet cluster at about 10 o clock!  says cruise control  on .
Brett
Not a 2nd gen there isnt! ;)
On the level to the left hand side of the wheel press in the round button, this will turn on the cruise control system.  Once you have accelerated to your desired speed, press and hold the orange set button on the end of the stalk, as the cruise control engages you should feel the accelerator drop slightly from your foot.  If it doesn\'t take your finger off of the orange buttin and try again. (For some reason it occasionally takes 2 attempts on some 2nd gens!)
 To coast flip the lever down, to resume after touching the brake pedal, flick the lever upwards.   To accelerate whilst in cruise mode, hold down the orange button.
 Hope that helps - and not trying to shout you down gergriffinrx7 :wave
Brap Brap Brap Brap
banana-man666
Cool. Cheers lads. Not sure if I will ever use it more than the once to see if it works but I hate having a bit of the car that im not sure how to use!
Brett
Its good on the motorway if you want to keep fuel consumption down :yes
Brap Brap Brap Brap
gergriffinrx7
No prob Brett
I\'m talking about a third gen  fd
Ger
grinder
moved to correct section
The tightest man on earth
:Giggle
banana-man666
How did this get in here??
Question was about a 2nd gen FC
grinder
oh shoot - my bad :D
QuoteI\'m talking about a third gen fd
i thought you posted that :D
:Giggle
Brett
/cough/ :rollin /cough/
Brap Brap Brap Brap
