knock sensor problems
Started by wow, November 09, 2007, 06:56:27 AM
wow
Hi all,
i was just wondering where the knock sensor is located as yesterday i started getting constant readings of 122 knock level even with the smallest of throttle and even as high as 196.
so just wondered where the sensor was so i could take a look,  also does anyone know how much they are if mine is  dead.
cheers
nikp
Front rotor housing, above the spark plugs, on the plug side.
davehg
japjim
#4
sorry to hijack thread but could anyone answer my question/issue,
i am seeing high knock readings of above 100 at times not neccesarily when on heavy load but when excelerating slowly through gears aswell, at around 5rpm, dosnt always happen.
any ideas?
thanks
Jay
banned advertiser
Check underneath car, sometime when de catted the sensor is just tied up underneath, Ive seen them just tucked up, if it gets lose it can send a signal that will make light flash.
