Engine Stand adapter plate
Started by Sidzrx, October 09, 2007, 03:20:48 PM
Sidzrx
Does anyone have an engine stand adapter plate/ the specification for one? As I either need the specification so I can make one, or be able to buy one from somewhere.
deanflowers
i managed to use the standard mounting points on a cheap £50 sealey one from the local motor factors, not sure on the specific model though sorry
imebgo
The ones off ebay work, you can line it up with 3 of the holes on the front plate if you take the front cover off...
http://cgi.ebay.co.uk/NEW-750lb-340kg-Engine-Stand_W0QQitemZ300157845669QQihZ020QQcategoryZ30928QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I think thats the one I used (or an 1000lbs one) just make sure you assembly it to the engine with positioned away from the plate, else you wont get it back together again ;)
James
