Bit of a request and some questions
Started by fdlover, October 09, 2007, 01:28:11 PM
gsb876
Quote from: lockwood77Mine sits below 70 degrees when cruising, even after two hours of driving! :xconfused
Could just be the sender to be honest, or probably the fact that I was cruising at 70mph+ off-boost when I noticed. I can\'t see it being unsafe to go WOT if the engine\'s been running for that long, even if the oil temp says 55-60 degrees. Water was ~81-84, depending on the weather.
No you\'re right, if the engines been running for a while but your oil temps are usually low anyways then its fine bud, hows it going with the RX - you loving it mate  :Laugh
lockwood77
Certainly am mate! :D
First trackday at Donington a week on Sunday!
