Resetting a PFC??
Started by $mila, October 03, 2007, 10:26:51 AM
$mila
Iv got a 1995 FD3s. apexi already fitted with commander aswel. Iv had a bad hunting problem. This was due to a manifold gasket leak, this has been fixed and when started with standard ecu idles fine, but when i put the apexi back on, it starts hunting again. i have no manual with the apexi and was just wondering if anyone could tell me how you reset the apexi ecu to the base map???
mx1311
Matt_K
On the Commander, go to ETC --> All Data Init --> Yes (and press next)
Then turn your iginition off and on. That\'ll reset it to the base map, but you\'ll lose any map on there currently forever. It\'ll need to be remapped again from scratch.
IIRC too most (not all) unmapped Apexi\'s hunt between two idle figures. Mine used to hunt between 750 and 1500 a few times before settling down. It did this every time I came off the throttle or turned on any electrical items, demister, lights etc. Now it\'s mapped it doesnt do it anymore.
http://www.apexi-usa.com/pdfInstallation/12.pdf <-- PFC Manual in English. Page 41 of the PDF File.
