air pump on fd3s
Started by rico2k_uk, September 20, 2007, 12:56:09 PM
Scott Zimny
I found the air pump quite easy to remove...as Lum said its only really 3 or 4 bolts that hold it on. I just followed back from where the air pump connected and removed everything that was connected to it, its quite surprising what you can take off in the end.
This is the wee write up i did of it when i removed mine...
http://www.mazdarotaryclub.com/forums/showthread.php?t=37524&highlight=air+pump+removal
