Compression Testing
Started by leeroy_25, August 31, 2007, 07:34:35 PM
ianelvar
Sounds a bit weird on the compression readings. What tester are you using? I used one of the standard gunson ones which worked OK, and got 6 bar (ish) on each chamber when I did my test cold and with the engine out of the car. I\'d be tempeted to just chance it myself, but I normally get burned by decisions of that nature. Think I just have bad luck.
leeroy_25
I would say more often than not when it comes to cars I also have bad luck! I used a draper tester..? Don\'t imagine there can be muh too them whatever make?!
Lee
