Air temp sensor giving weird readings
Started by Kash_, July 05, 2008, 12:45:33 PM
Dr-Rotor
Now that its all good thats fine. I was going to say if you have a PFC ECU with the hand controller you could have gone to the ETC section & looked at the sensor page. It would have highlighted the Air temp sensor to show you it was fubar.
Remember this the next time you have faults with sensors...PFC will show you by highlighting it.
nikp
Quote from: Dr-Rotor;524186Now that its all good thats fine. I was going to say if you have a PFC ECU with the hand controller you could have gone to the ETC section & looked at the sensor page. It would have highlighted the Air temp sensor to show you it was fubar.
Its very handy that feature.
Kash_
Yep very good feature....I had already checked this, but whenever I looked at it, it said the sensor was fine.... just my luck that it used to go weird randomly, moreso when I was driving instead of on idle....
Dr-Rotor
You can just leave it on that screen while driving to monitor it. Anyway its all good now.
Faffer
Very handy, thanks! Now to work out what all the abbreviations mean...
Dr-Rotor
It tells you in the manual. If you dont have one I will email you one if you like.
Do you guys know how to setup your watches so that you can monitor up to 8 things at once? Id say 4 is enough. The 4 most important to me are Boost, Water temp, Air temp & Duty cycle. You can set it up to record the highest values. When its in this mode you will see smaller dark boxes to the right of the larger numbers...these boxes show the peak of everything & can be reset each time with the push of the right arrow.
To get them to display I think you push the up arrow or down...wont do anything to the map when you are in the watch mode so dont worry about pushing them. If you push the left arrow it will pause the lot...to undo just push it again.
If anyone has difficulty understanding this I will make a small clip or just send pics.
