quick question about suspension removal
Started by wee_blim, September 30, 2007, 12:43:26 PM
wee_blim
Is it possible to remove/replace standard/aftermarket suspension on the front without removing the top wishbone? I.e. will the shock be short enough with the spring attached to wiggle out from it?
cheers
Jit
i dont think you can do it without removing the upper arm
shaunwil
If you are lowering the height of the car then you would probably need it tracked again anyway. Mark out the dialed faces when you remove it and it should be similar to where it was before.
Shaun
Quote from: wee_blimIs it possible to remove/replace standard/aftermarket suspension on the front without removing the top wishbone? I.e. will the shock be short enough with the spring attached to wiggle out from it?
cheers
You need to undo the roll bar links and the upper wish bone from the body so you can lay back the upright and slide the strut up through the wishbone
Hope this helps
RemarkLima
As said, not a chance without removing the upper wishbone. But it\'s only 2 bolts per side so not very hard at all.
FLAT4MATT
Yup gotta undo the upper wishbone, dead easy though!
