19 inch split rims
Started by Hound Dog, January 05, 2004, 07:24:18 PM
Hound Dog
i am looking at buying 19 inch split rims , has anyone fitted 19 and are they okay or am i better going for something smaller?  ta
Fishy
You could get wheel rub on either the arches or the struts. So offsets would have to be spot on.
Plus I think ride could be a little harsh.
Dan
StreetPizza
I guess it depends what you want from your car. For shows, and a bit of cruising around and looking good, then 19\'s should work. Just be sure you get the offsets right.
If you care more about going fast, I think current advice (picked up by lurking Yankee forums) is to go no bigger than 17 or 18.
Also depends if you lower your car, I guess.
DRAGON
If you go for 19s, I would recommend you have the front arches rolled. Big alloys tend to pull the lip of the arch out otherwise.
Hound Dog
i have found these 19" and they have 34 offsets and he thinks they are the right fitment , how much to get arches rolled just incase
Depends on where you take it. Different body shops charge different amounts.
