Fuel???
Started by frubes, February 08, 2004, 09:04:13 AM
frubes
What kind of fuel should i use in my FC non turbo with a ported 13B engine in??? What difference will it make, and what are the symptoms that using regular unleaded gives???
Cheers Guys
:wave
Iwan
#1
Hi,
when runing stock rotorhousing, use what ever you want! Also chep fuel is OK. (there must be just enogh fuel there ;))
The N/A comes with no knock- sensor so the ECU dont see any changes in fuel quallity.
Running the engine with knock sensor, requeres other fuel. Which fuel, depends on the ECU- map you are runing.
REgards
Iwan
still remember,
NO ROTOR, NO MOTOR !
