changing the clutch
Started by bally, August 16, 2007, 05:48:50 PM
bally
with a little help from you guys i will be changing my clutch just have a few question i hope you can all help with
1 unsure whats is in there at the moment replace the lot to be safe?
2 any bits while clutch is out worth changing?
3 if there is a counter balance on the fly wheel can it be removed or will i have to buy new flywheel as well?or at all?
4 it is a after market one in there and the idle is smooth is the fly standard?
cheers guys
Jono FD3
1. yep, replace the whole clutch, but if you can find out what is in there, then you might be able to get new clutch plate(s)
2. not realy...... don\'t chang your pilot bairing, it\'s an ars & yours sounds fine!!
3. shouldn\'t need to diturb the flywheel unless your changing the seal behind it, but yours should be OK!! so no need to worry about the counter weight eather!!
4. depsnds on what clutch system is in there!!!
J
