4" v band flange
Started by rx jamie, July 23, 2007, 08:10:15 PM
rx jamie
where is the best place to get one of these from in stainless steel. all i can find are 3"
cheers
MikeLMR
try commercial vehicle or HGV exhaust place, 4"+ is common and stainless is pretty commonplace too.
silverrexman
Quote from: rx jamiewhere is the best place to get one of these from in stainless steel. all i can find are 3"
cheers
Is it just the flange you want or the v band kit and flanges,if you only need the flange i might have one kicking about in the garage.Otherwise ATP as stated above or burns,both in usa,these are not as common as some people think.:wave
pdtaylor18
I can maybe get you one(aircraft spec mind you) it is a true v band and in stainless. will try to get one tomorrow from work.  These are really meant to join two flanges rather than the jubilee clip that just compressess.
Email: pdtaylor18@hotmail.com
Pete[SIGPIC][/SIGPIC]
rx jamie
im after a gt45 i have seen. the exhaust discharge/turbine side is obviously a v band and is 4" i was looking around for a flange to weld onto a custom exhaust down pipe.
silverrexman
Quote from: rx jamieim after a gt45 i have seen. the exhaust discharge/turbine side is obviously a v band and is 4" i was looking around for a flange to weld onto a custom exhaust down pipe.
What a/r is the exhaust side?1.32 would be 5 inch outlet on a gt45,is it a genuine gt or a masterpower smaller copy,believe me a gt45 or quality similar turbo is massive and would really require a 5 inch downpipe.:wave
rx jamie
gt4508  108mm outlet,  81mm inlet   .69 ar compressor 1.05 turbine ar
