Sunroof Problems
Started by FEED Rocket, July 11, 2007, 12:55:44 PM
FEED Rocket
Hi, my mate has an rex which is having major issues with the sunroof. Motor sounds fine but the sunroof won\'t open. It moves a tiny bit then makes a grinding noise. Any tips how to solve this problem?
CharlieP
Quote from: FEED RocketHi, my mate has an rex which is having major issues with the sunroof. Motor sounds fine but the sunroof won\'t open. It moves a tiny bit then makes a grinding noise. Any tips how to solve this problem?
Hiya, mine does this sometimes....
Try
1. Let go off switch then press again...it actually has two sections of movement....no.1 up...then no.2 up and back
2. Push on the sunroof slightly....ive found it just gets stuck a bit sometimes
FEED Rocket
Cheers dude. I\'ll pass on the message and see if it works.
FEED Rocket
It worked, G@ndy sends on his thanks! Excellent advice, cheers. :cheers
jon haines
silicone lube the runners and spiral dives if you can get to them. not specific to 7\'s but on all sunroofs in general the grease will dry and harden, then cause more problems than it solves. silicon(or ptfe) spray will soften the grease and help free the roof.
