Possible Cosmos transplant???????
Started by RX7 R2, July 05, 2007, 06:54:58 PM
John Yorke
Best check the year of this Cosmo as stated before on earlier models the engine mounting points are on the center iron, the later Cosmo RE lumps had the tappings on the rear which make the conversion do-able, there is quite a bit of fab work required you will need a spacer block milled out so that you can use the REW throttle body with the RE UIM and to give you more clearance you need to reduce the LIM by about 25-30mm and you will need a different 2ndary injector rail as well as a few other bits, the REW loom is fine, what costs is the rebuild and the ancilaries to make it a safe powerfull engine. As Ant has said if you are looking at 400atw you can do this with the REW and save yourself all the hassel.
