Have I done this right??
Started by evo_ray, June 14, 2007, 02:26:20 PM
evo_ray
OK, just checking as I cannot seem to limit boost on my 7.
I have a Blitz Dual SBC which was already fitted in the car but was not connected to the Turbo/actuators.
What I did......
Took the two outlet pipes from the turbo and connected to the inlet of the SBC and then took two pipes from the outlet of the SBC and connected into the top of each actuator.
The car was only acheiving 0.57 bar boost before but now it goes upto 1.24:2eek  I\'m trying to limit it but can\'t seem to do it!!
Just needed to check if I had plumbed the SBC in correctly.
m4drx
if you have the pills bro and save some time and use them if your not going to run higher boost i did for a while then took em out when i had time to sort the controller.
also controller boost control solenoid may be duff hence why it may have been disconnected.
just a thought, but whatever you do get the damn thing working and enjoy!
fduk.
evo_ray
Quote from: m4drxif you have the pills bro and save some time and use them if your not going to run higher boost i did for a while then took em out when i had time to sort the controller.
Did you find the other pill pipe?  If not, I think I\'ll just have to go ahead and order some from somewhere
m4drx
i have one and ill have to have a look tonight if i can or tomorrow for you bro.
im going to the doctors at 5 so i might go up to putteridge then.
still off work :)
fduk.
evo_ray
Quote from: m4drxstill off work :)
you still suffering from \'tunnelrunitis\'?
m4drx
well traffic run didnt help things
fduk.
