Ignition
Started by jetpilot, June 07, 2007, 06:37:11 PM
kev-yorks
Quote from: jetpilotLooks like a good site, so which is the plug recommended?
Depends what heat range you want b9egv for stockish b10egv or b11egv for modified
Kevin
Regards Kevin
jetpilot
Thanks Kev, think the guys have put those plugs in now and they are 10\'s, so all being well, i might get a few more ponies now!
kev-yorks
One thing you will need to grind down the socket you use to fit these plugs as they sit within the case area of the plug hole. It only takes a couple of minutes if you\'ve access to a bench grinder take about 3mm of the outside of the socket to the point it is about breaking through on the corners. Don\'t worry about the socket walls opening out as the casing keeps them in position.
Kevin
Regards Kevin
