Belt needed after removing aircon pump
Started by the_muzza, May 26, 2007, 06:26:17 PM
the_muzza
Hi all,
Quick question if I may, I\'m just finishing up my engine swap and single turbo install, and whilst everything was out I decided to ditch the aircon. My problem now is I have removed the aircon pump I need a new belt to drive the power steering by itself.
Does anyone know which belt I need for this and where I can get it from?
I have searched but can\'t find anything relevant.
Many thanks in advance
Doug
John_Hudson
Shyauto supplied mine cant remember what size it is though =/
rx7veilside
give carl hayward a call he has just done mine
ttpower
Lum
got mine from halfords mate. cut the old one to the length i needed then went to halfrauds and found one the right size! I\'ll go out and have a look if it\'s got the part no written on it when it stops raining!
interloper393
does the aircon pully n belt weight much?
Hayward North
Whats tentions the belt when you remove the airpump ?
Thought the airpump was also the tentioner.
Regards
Steve Garbutt
Hayward Rotary North
Jono FD3
Aulternator & air pump move.... so you can just use the aulternator to tighten the belt!!
Jono
Hayward North
Quote from: Jono FD3Aulternator & air pump move.... so you can just use the aulternator to tighten the belt!!
Jono
Ah silly me.
Regards
Steve Garbutt
