FD ACT HD 6-Paddle Clutch. Experience?
Started by Tiger_kpt, May 22, 2007, 01:22:11 PM
Tiger_kpt
Hi guys. I\'ve done just over the 1000mile mark since I had a load of work done and parts fitted by WGT a bit ago.
Some of the parts were as follows: -
ACT HD 6 Paddle Clutch kit Part Number # ZX3HDR6
XACT Streetlite flywheel part number # 600145
ACT Counterweight flywheel part number # CW01
[/COLOR][/I][/SIZE][/FONT]I\'m just wondering if any of you guys have this exact same combination fitted to your FX7 FD?
The combination grips great but think I am having a few teething issues. It maybe just the fact that i\'m not used to such a type of clutch. But the combination is what I would call unforgiving. It\'s either on or off - hardly any "in-between" phase. Comes accross as being a tad harsh.
Also getting like a loudish screeching noise and juddering coming from the clutch when setting off in first gear under low RPM. As well as the screeching noise whilst driving along at medium - high RPM in a gear and dropping down a gear (off throttle).
Apart from that no concerns. Just a bit annoying. Cheers.
MikeLMR
sounds about right paddle clutches don\'t slip much and are harsh especially if you don\'t have a sprung plate.
but what do you expect from a clutch that is basically a race derived design ... I doubt ANY oem would fit a paddle clutch, they would go for a multi plate design which can be made to operate almost like a "standard" unit but take massive amounts of torque.
Ed_RX7
as mike says find out if you got a sprung plate
Edrx7Parts
07531 669 768
Also of
LRP
i hav same setup and yes it either on or off and noisey !!
complete wankel :god
RobMatthews
i have same clutch with standard flywheel dont have a problem though with it
,is a bit on or off but just got used to i.
parts supplied by;
DM-Motorsport.co.uk
Info@DM-Motorsport.co.uk
Ed_RX7
the sprung disc should make it quieter.....is this what you have?
Edrx7Parts
07531 669 768
Also of
BlitzBoy
I had the that set up on my white car, awesome set up bites stright away but u cant slip it really, holds plenty of power :D
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
Ed_RX7
sprung or unsprung?
Quote from: BlitzBoyI had the that set up on my white car, awesome set up bites stright away but u cant slip it really, holds plenty of power :D
Edrx7Parts
07531 669 768
Also of
BlitzBoy
New Project
bobert
You running a similar set-up to me.
I use the 8 puck unsprung disc.
It’s a bit harsh but theirs no chance of it slipping:D
Tiger.
Have you sorted that problem with your pfc?
BlitzBoy
yep it is a good setup. I used ACTs on my 300zxs years ago and they used to thump out hell of a lot of torque
On my black car now I use an OS Giken twin plate setup with flywheel, had it rebuilt and it bites like a b&tch now although I can slip it a little
New Project
Tiger_kpt
Hi all. Thanks for your feedback. Pretty sure that it is the unsprung plate. There were no built-in springs present on the 6-paddle clutch friction plate - if that\'s what you mean.
Yes bobert - all sorted mate. Somehow managed to get water in the PFC via the Commander socket. Took it out. Opened it up. Hairdrier, cotton buds and a night on the radiator soon sorted it. Plugged it back in and it fired up first time. Madness.
