Steering Wheel Hub
Started by chrisJDM, May 23, 2007, 10:59:06 PM
chrisJDM
Ive been looking at replacing my steering wheel on my FD with a smaller item but cant seem to find any hubs that fit a FD only ones for the FC.  I like some of the Momo steering wheels but woteva i can find a hub for really, ive seen a few other threads on here or the same thing in the past but they didnt get many replys
davehg
you can order a momo hub from the likes of halfords
chrisJDM
sounds good, do they do them for the FD thou?? i found a few old threads on here that say they only do MOMO ones for the FC??
efiniste
You can use an FC one. If you want to keep the existing horn arrangement (rather than rewiring it) you\'ll need to drill a hole in the hub to let the horn connector come through. Other than that it\'s a straight fit.
Steve
chrisJDM
sounds good, ive seen some cheap steering wheels with hubs on ebay, they look ok and will prob do the job, so they would be fine as the hub should fit even thou its for a FC??
efiniste
yep, that\'s what\'s on mine with a Momo Corse wheel. I\'ll get a pic of it tonight if I remember.
chrisJDM
ok cheers thanks for the help i will see wot i can do, might get a cheap one for now of fleebay and see wot its like
