Changing shifter
Started by dhracer, May 14, 2007, 09:02:13 PM
dhracer
I\'ve removed the rear two bolts but can\'t for the life of me get to the front two properly and I don\'t want to round them off.  Is there any other way to get to them :confused:
EDIT: sorted now :) brute force and ignorance did the trick (used a bar to leaver the transmission about) only problem is the damn nylon cup in the shifter was already broke so I\'ve got to get hold of one before I finish fitting the new shifter :mad:
davehg
#1
i have a spare shifter, should the nylon part be attached to the shifter? is so then its all there.
dhracer
yeah the nylon cup should be on the ball joint end of the shifter if it isn\'t already broke?
fancy selling it to me?
