How to remove gear lever ext housing?
Started by Martiny, April 22, 2007, 09:47:46 PM
Martiny
Hi guys
As per the title...
1981, 1st Gen gearbox, 5 speed.
I need to remove the gear lever housing. I have undone the 4 x 12mm bolts, and I have removed the little plate cover the end of the housing. So I can see the shaft.
The housing is actuall loose, I can pry it away from the gearbox a little, but I am loathe to bend or break something.
How do I remove it?
