FEED torque brace pics
Started by SCOOMER, September 15, 2005, 06:20:30 PM
SCOOMER
Tryed it the other day and gave it a good thrashing, yes theirs less engine movment but you can hear a little bit of vibration through the body. I\'ve read some people place a rubber strip between the damper and body but i think this is defeating the object.
Anyway im happy with it as is.
Scott
PETE SMITH
The piston length determines the solidity-the noise, which i get, is between the end rings and the bolts, so a piece of suitable "rubber", wouldn\'t effect it\'s performance..or maybe i\'m talking thru me ane!! :evillaugh
craigr
I swallowed the bullet and bought one from ebay. Have fitted it, and it appears to match the pics on this thread. I do get a rather nasty metallic rattle every now and then at idle and when I shut the car down.
I\'ve double checked tightness on all bolts, and it clears all surrounding bodywork/components. Does anyone have a similar problem ?
PETE SMITH
Hi Craig,
I\'ve concluded that even if you tighten it to the max, you\'ll still get this "rattle"-nothing to do with it\'s effectiveness, just the end bits rattling-I\'m going to get some cushioned nylon o-rings-B&Q plumbing section i believe!! :D
Saying that, i\'ve got use to it!
Pete :guinness
Newera
I have one on my rex too It used to rattle, so I lengthened it with adjustment and it\'s silent always now. Just need to adjust it till it stops rattling.
These are good for stopping your engine flexing the drive train when accelerating hard - so will help preserve the power frame under the car, which can crack and eventually snap at the rear from too many hard starts...
I\'ve had mine go once, so in addition to a new uprated power frame, I got this brace, RE Amemiya uprated engine and diff mounts (Harder rubber - not solid alloy) - not had a problem since. :)
We supply this brace inexpensively too - see //www.neweraparts.com :D :D
VISIT OUR WEBSITES!!!!
A Tuner\'s Paradise
Automotive Art On Film
Dedication To Automotive Perfection
Newera - Japan. Tel - (Calls charged at UK National Rate): 0207-193-3979.
Mobile (Japan): +81- (0) 90-4133-3825  Fax (Japan): +81-(0) 47-307-4678
craigr
so a quick question - how do you adjust it ? I tightened everything up as much as possible and still had to push the engine block over a tad in order to get the 2nd bolt to fit in. I have added some O Rings (good suggestion) and things appear to have quietened down a bit.
Cheers, Craig
Newera
Undo the locknut, then turn the "damper" body whist holding the shaft in place. Not sure if you have to have one end disconnected, maybe.
A Tuner\'s Paradise
NurburgRob
Quote from: craigrso a quick question - how do you adjust it ? I tightened everything up as much as possible and still had to push the engine block over a tad in order to get the 2nd bolt to fit in. I have added some O Rings (good suggestion) and things appear to have quietened down a bit.
Cheers, Craig
Going to fit my FEED Torque Brace tomorrow (finally) and wondered who has added rubber or nylon O rings and exactly where you fitted them?
I\'m guessing between the body and the bracket?
Where did you get the O rings from?
& How tight should I tighten it, I\'m assuming it will begin to push the engine over but I don\'t want to \'over do it\'?
Thanks for your help!
RobbieRX-7
My tourqe brace annoys the **** outta me. Gotta find some way of stopping the rattling
NurburgRob
Exactly, I want to avoid this as much as possible!
RAW
mine rattles and really annoys me, even though it\'s really tight, so i have put 2 large rubber washers (from Halfords) between the bolt on each end and the body. works a treat. they come in a small plastic box and would normally be used to line holes in panels but still aloowing you to put something through the hole. :driving
NurburgRob
Thanks, I will try this.
Just discovered that my alarm switch for the bonnet uses one of the holes for the bracket aaarrrggghhhh, more hassle moving that then.
stylus350
I cut a bit of rubber pipe, took the bolt out of one end and put it between one end of the swively bit and the mount, bolt back in. The brace does not twist at all now and it is silent.
