Leaky waterpump - whats the way forward
Started by leon, June 02, 2007, 01:47:11 PM
leon
hey Guys rebuilding the car after the rats nest work! man that was a ball ache had its highs and its lows, moments where i just wanted to throw it all and give up but in the end got it done :wiggle
i did a quick look on the leak while i had it all out and it turns out my waterpump is ****ing water out from underneeth it, is this a fault thats liable to kill the car? or can i live with it for some time. also how much of a job is it to get fixed need i take it to WGT etc?
Leon
:cheers
I woof in your general direction.
K1HKS arse
If its leaking from the little hole in the underside of the pump then its knackered mate, you need a new one. If its leaking from the gasket then not so expensive to fix.
Any coolant problem should be fixed straight away really, you dont want to destroy engine due to overheating.
