seatbelt warning driving me nutts !
Started by scientist1968, April 10, 2007, 05:41:43 PM
scientist1968
...the warning light on the dash is flashing and beeping constantly, can anybody tell me how to make it stop ??
(yes i have put my seatbelt on !)
tried;
1.undoing the connector under the seat.
2. taking bulb out off dash.
3. taking out fuses, but it runs off the power windows and dash circiut.
a set of wire seems to go to the inertia reel seat belt housing, so i guess there is a switch or sensor in there ? Can\'t find it on my wiring diagram.
If you have encountered this annoying problem b4 what was your fix ?
RobbieRX-7
Sounds like your F100 ecu unit is faulty. Do a search for F100. there has been many threads about this
andyroi
sounds like it could be that, does it also affect how your electric windows work? mine did exactly the same! it may also be marked as F110. not sure if there is any difference, the F110 was faulty on mine, replaced with F100 and worked fine. maybe just different marking for different year of manufacture?
scientist1968
thx guys. yeh the power windows are messed up and work in short bursts!
the search function isn\'t working for me...any more info ?
What was the cost of replacement and is in located in the drivers footwell ?
ta.
scientist1968
Mave
Yep, sounds like the F100 box. Seatbelt light flashing and buzzing, drivers window only going up in spurts in time with the buzzing.... Got my replacement for about £60 from Jimmys IIRC.
adib
mine has been disabled in japan and elec windows work ok, all i get is a clicking noise for some where behind my head when i plug belt in
RobbieRX-7
I wouldn\'t reccommend disabling the f100 unit. You rely on that if you ever get a coolant leak the alarm beeps. Also it\'s a nice feature to have the beeper at the top end of the rev range. Mine doesn\'t beep if you haven\'t got the seat belt on though, only when low on coolant, lights are on or keys in the ignition, now that does my head in!
If you do a goole on Clive Haynesford you might notice a thing about putting a sticker over it. ;)
adib
robbie my coolant alarm still works and so does rev limit alarm, so f100 unit must be pluged in still
