speedo not workin rx7?
Started by Boywhizzz, April 09, 2007, 10:38:49 AM
Boywhizzz
any body know why a speedo wouldn\'t be working on a j plate rx7? :2Confused
ttpower
check that your speedo cable hasnt come loose out of the gearbox!!
Boywhizzz
Quote from: ttpowercheck that your speedo cable hasnt come loose out of the gearbox!!
do they have cable? n do you know where abouts it is please?:god
shaunwil
Lol, the speedo is electronically controlled. Could be that the speedo has a fault, the conversion electronics have come loose or a sensor has broke.
Most likely there is a problem in the gauge cluster and something has died.
If you search for speedo there is plenty of information for both removing the dash and checking the parts.
Shaun
ttpower
hhmm, bit different to my integra lol! just tryin to help out. So would that mean it reads the speeds though the abs unit? if so mate, check your fuses?  be a good place to start.
Boywhizzz
Quote from: ttpowerhhmm, bit different to my integra lol! just tryin to help out. So would that mean it reads the speeds though the abs unit? if so mate, check your fuses?  be a good place to start.
hey i didn\'t know that. my abs not working either. but checked all the fuses and there ok. now really not got a clue what it could be:2Confused
ttpower
#6
did your abs stop working round the same time as the speedo, have you got an abs light on the dash? check all your connectors are plugged in and have good connections, the abs module is in the top right corner of the engine bay. Other then that i can only think of it being a faulty wheel speed sensor (abs sensor).
Boywhizzz
Quote from: ttpowerdid your abs stop working round the same time as the speedo, have you got an abs light on the dash? check all your connectors are plugged in and have good connections, the abs module is in the top right corner of the engine bay.
not sure matey as they was not working when i got the car. but yes i\'ve got the light on the dash. i\'ll go have a look now for the abs thingy. n thanks for your help. i got no idea what i\'m doing lol:god
shaunwil
If you do a search for dash removal there are a couple of really good write ups on how to do it, usually the rev counter goes wrong and can be caused by faulty capacitors on the instrument assembly.
Shaun
