Which spark plugs?
Started by Jim_rx7, March 15, 2007, 02:37:33 PM
Jim_rx7
Which spark plugs should I be using in the rx7?
Gonna give it a service (just got the car). Also where can I buy them online? I\'m running standard boost pressure at the moment.
thanks in advance.
Mazdarotaryparts
Hi Jim,
We can supply your spark plugs at £38 delivered and any other service items you may need, if you would like to have a look here you will find a service section for your FD along with many other goodies
http://www.mazdarotaryclub.com/forums/showthread.php?t=34439
Hope this helps
REgards
Clive
Mazdarotaryparts
Racingbeateurope
Racecarbattery
shyauto
Illyont
Quote from: Jim_rx7Which spark plugs should I be using in the rx7?
thanks in advance.
You could use NGK EQ9 or whatever they are called. Some people use EQ7 and EQ9 (leading and trailing), but some use just EQ9.
(names might be wrong, but NGK website should display these are "stock replacement" plugs).
banned advertiser
