WTB: RX3 (Coupe) lower rear quarter panels...
Started by 20B_boy, February 19, 2007, 09:44:21 PM
20B_boy
Long shot, but as above - anyone any thing lurking anywhere or know of similar some where? need the very lower parts - basically the arches, both 1/4\'s are good just the arches are a bit of a mess.
Or - anyone know if wide arch kits are available from any where atm?
I\'ve had a bit of a scout about but not turned that much up thus far...
Ta,
R.
R.
MikeLMR
had you thought about using some arch repair sections from somthing similar but more common?  will be a bit more work than proper Rx3 ones but a lot less than getting some made/hand fabricating some.
20B_boy
Quote from: MikeLMRhad you thought about using some arch repair sections from somthing similar but more common?
Do you have some thing particular in mind Mike?
R.
MikeLMR
strugling to think of somthing that matches in that area, if it were more of the arch section rather than where it blends into the rear end it\'d be a little easier, tried a few by looking through piccies on google but nothing that stands out.
What you could do with is a load of photos of a good one and find somewhere than has a large stock of 1/4 panels :)
Wide arches might be an altogether easier option.
