Making up steel pipework...
Started by interloper393, February 13, 2007, 02:00:08 PM
interloper393
Hey guys just wondering, iv read that installing a bigger intercooler you need a remap, at the mo iv got a standard smic but i want to replace all the rubber hoses and pipework with refabricated mild steel ones, is 3" big enough and will it cause any problems?
cheers :Hammer
Did you get one of those Godspeed V-mount\'s of Ebay? If so is it any good?
As for the Piping, i\'ve just made a set of pipes for a mate here. His FMIC has 3" pipe work too and from it (it was made easyer as the IC had 3" pipes welded to it) I here people using 2.5" to 3" on road cars with little problem.
Like anything if you alter the Air density or Fuel you need to remap it, but saying that if you have a Air temp sensor in the Inlet it should pick up the temp and ajust acordingly (its only if you up the boost i think it would be a problem?? but worth getring it mapped anyway when its all done)
interloper393
really just wanted to tidy the engine bay up but dont wanna have to buy a power fc n remap just to do it lol..
tbh you can\'t do alot on a Stock ECU without needing to remap it, i supose it all depends on what you have already.
Without a EMS its a bit Guess work, you realy don\'t know how much it will flow better than the stocker etc
Timrxmotors
Buy some aluminium pipe and use that,it won\'t rust inside.
Do you have a pic of what your doing? I have some HKS hard pipes if they would help ;)
Cally
You making the pipes yourself? Drop me an email scottcallan@gmail.com
interloper393
iv got the hks ones, from the elbow to the hks pipe id like to make and the left side of the plenum to the intercooler, n poss the air filter ones as iv got the hks filters with existing rubber pipes.. :)
